Most window units use the water in pan and throw it upon condenser which evaporates it. need to check if its level side to side with a slight tilt to the back in window.
I have this problem too. I pulled the window unit out of it's sleeve (Friedrich Quietmaster 2008 SS series) and saw two oval holes in the front about a half inch up from the pan on either side. They were about an inch long by a 1/4" wide. They were clear.
I think the problem is that under the colls in the back of the ac is rotted from water accumulation so the water doesn't flow under the fins to drain out.
I will try to make a passageway so that the water does not build up.
It's not the angle and it may be that the ac is too small for the room and the water continously builds up and does not drain out because of the rotted fins at the back but what do I know.
SOURCE: re: friedrich model # EL25J35-A
Dont pull the unit out, you may damage the lines that carry the freon.Your drain may be stopped up. try pumping it out by hooking up a shop vac to the drain from the outside, this should pull through any debris loose that is blocking the water from draining.
SOURCE: A/C unit leaked out of front
pull out the unit and make sure the drainage is not clogged with slime and dirt. there is a drainage from the front to the rear. clean it before putting it back and tilt it a little bit towards the back too as you return i in place..
i hope i was able to fix your problem...
pls rate me..
tnx,
drcool
SOURCE: My quiet master is leaking
1. check the filter.2. remove the front cover and check the front coil behind the filter and check any drains that might be plugged. some units do not have drains and if not that is fine. 3 Be certian that the unit is tilted to the outside about 1 inch or so.. It should then drain as it is designed.. hope this helps let me know.. Jon
