i-mate Jama 101 Smartphone Logo
A
Anonymous Posted on Aug 12, 2014
Facebook login I phone 5 how can I login to both my mobile and home computer, I just can not seem to.
5helpful
2answers
How to login a messenger whout Facebook account
If you want to use facebook messenger without accessing facebook account so you need to follow these given steps:
    ·Open the facebook messenger app
    ·Then submit your email I.d or mobile phone number
    ·Then confirm your mobile phone number
    ·Then sync your all contacts
    These are the steps to access facebook messenger without open facebook account but if you want to get help so visit this link: Solve Facebook Messenger Issue
2answers
Add my phone to my facebook account?
From your computer, you can go to your Mobile Settings to add, remove or edit phone numbers.
If you already have a mobile number on the account:
  • Click Add another mobile phone number to activate another number
  • Click Remove to remove any of the numbers that are already listed on your account
Not able to access on facebook news feed on mobile and home pc
If you want to acress from phone you have to get facebook code
https://www.facebook.com/mobile/
faster that you are able to login with your cellphone .
2helpful
SOME HAS REMOVED FACEBOOK FROM MY COMPUTER
To safeguard user privacy, the Facebook login process requires the input of an email address, username or mobile number as well as a password.
While you may opt for the "Remember Me" and "Remember My Password" features on your personal device, there may be times when you need to manually log in to your account.
If you're not able to locate your account from the login page, there are several steps you can take to recover it.Invalid or Expired Email Address
1. If you no longer have access to the email address that is linked to your Facebook account because it is invalid or expired, locate your account by logging in with an alternative.
If you registered a username, enter it in the "Email" field on the login page.
Enter your password and select the "Login" button. If unsuccessful, type your mobile phone number in the "Email" field on the login page.
This will work if you've registered for Facebook texts.
If unsuccessful, type an alternate email address in the "Email" field on the login page.
If you are still unable to identify your account, complete and submit the "I Cannot Identify My Account" report, which you'll find at facebook.com/help.
Click "Browse Help Center Topics" in the left column. Click the "Login & Password" option under "Managing Your Account."
Click on "I Can't Remember Which Email Address I Use To Log In To Facebook" and click the link in option 5.
Click the "I Can't Identify My Account" link in the lower-left corner of the resulting page to access the report.
2 . After you've logged in, click the "Account Settings" option that appears in the "Account" drop-down menu in the upper-right corner of any page.
3. Click the "Change" link next to the "Email" option of the "Settings" tab.
View your current email settings and edit as desired to manage email addresses that can be used for login.
Invalid Password
4. Visit facebook.com/recover.php in your browser.
5. Enter your email address or mobile phone number in the "Email or Phone" field that appears at the top of the page or enter your Facebook username in the space provided.
If you don't know the email address, mobile phone number or username that is associated with your account, type your name and the name of a friend in the spaces provided at the bottom of the page and click "Search."
6. Type the words that appear in the resulting security box to authenticate your request and click "Submit."
7. If the information that appears on the resulting page matches your account, click the "Reset Password" option to access your account.
https://www.facebook.com/recover.php
Identify your Account
http://www.facebook.com/help/?faq=18012
How can I make sure I don't lose access to my account
2answers
I forgot my facebool account imformation
Invalid Password
Cant Login to facebook
Logon your facebook account pm another computer with another (a different) internet connection to verify your account. Error seems to be due to two devices on facebook at the same time on the same internet connection, e.g. your home internet.
2answers
I can't log on to facebook
Are you sure you're using the correct email address & password that you used as a login? Typing mistakes are a common reason for not being able to login. If you don't remember your password, you can have it emailed or sent as a text to your mobile phone (if you set up your mobile in facebook). On the facebook home page there is a "forgot your password?" link you can use.
I tried to log in to facebook from my phone and when i enter my info and click ok it only takes me back to home screen and says i need to log in. i tried loggin in on someone else's account and it worked....
Issue: i tried to log in to facebook from my phone and when i enter my info and click ok it only takes me back to home screen and says i need to log in. i tried loggin in on someone else\'s account and it worked. what could it be?
Causes and solution:
1) There are chances that the Facebook Account login account and Passwords has been mistyped.
2) There are also chances of the Facebook password hacked.
Note: I recommend you try logging into the FB account in the Computer and check if it is working.
If not the passwordis hacked and you need to answer the security question then get back the access. DON'T FORGET TO CHANGE THE PASSWORD AS SOON AS YOU LOGIN.
You can also check this link: http://www.facebook.com/mobile/ Use that application in the mobile and try logging using that.. remember to uninstall the previous application you're using before you're installing this.
The above following steps should resolve the issue.
Revert me if you have any problems or need more attention on this issue :)
29helpful
8answers
Facebook mobile login not working...
I am now able to login to Facebook with my mobile.
I select the HTTP login at the bottom of the screen and then I had to re-enter my login info and I was able to get to my home page.
The only thing I did was on my java settings I selected the media profile...not sure if that was the reason why it wasn't working but it is working now! If you do get on, Book mark your homepage and then you shouldn't have any problems getting back to it in the future! Hope this helps!
Top i-mate Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
