SOURCE: Can Not remove print cartridge from PSC1610
HI BILLF6330 , YES DIFENTELY IF YOU FORCE MUCH CARTRIDGE ASSMBLY WILL DAMAGE SO DONT DO FORCE FIRST YOUR REMOVE ABOVE SCANER ASSMBLY WITH SIX STAR SCEW DRIVER AND REMOVE SCANER DATA CABLE AND SWITCH PANEL CABLE THAN REMOVE CARTIRDGE BALCK ASMMBLY WITH LOCK THAN REMOVE CARTRIDGE AND ASSMIBLE IT
SOURCE: hp psc1610 all-in-one after market ink cartridge problem
The following cartridges are supported by your product
black inkjet print cartridge - HP 94
tri-color inkjet print cartridge - HP 95
tri-color inkjet print cartridge - HP 97
photo inkjet print cartridge - HP 99
SOURCE: Error message Incorrect printer cartridge (but it is correct )How do i correct this error
I've never encountered a problem like yours on the HP78 cartridge or even the HP15. Have you tried cleaning the cartridge as well as the printer pin? The only time we had this problem with one of our customers, we cleaned the cartridge and the printer pins and the problem was gone. Let me know if this helps.
SOURCE: want to install HP psc1610 printer
Go to www.hp.com and let the website auto-detect your printer and download the drivers automatically
SOURCE: MY HP PSC1610 ALL IN ONE PRINTER WON'T PRINT AND
Open up top/sides back, carefully check inside, you should find you have a piece of paper fouling out the in sides, if lucky should be able to remove by gentle but firm pulling motions.
Close all open parts then restart printer. If you still get error message, recheck for further paper jamming inside.?
