The clock battery is not charged;how do I recharge the clock battery
The clock battery is internal and cannot be removed or replaced except by a technician. It is recharged by your regular rechargeable battery, so there is no separate charging procedure. If you find that your clock and other permanent settings are being list when you remove your regular battery for charging, then it's an issue with the internal battery and should go to repair.
SOURCE: Shutter Disabled
i was quated £250 to replace a buckled shutter unit can this be done any cheaper
SOURCE: I just purchased my Nikon Coolpix S4000 in June
could be a lose wire in the charger so the connection isnt getting through
i lost my camera charger, so i went to a store an bought an adapter for cameras and they are REALLY cheap!
you just put you camera battery into the adapter which goes directly into the sockets
so if you can t find any other solution this will probably be cheaper than by another charger for the camera!
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
SOURCE: How come my battery wont charge on my brand new
We had this same problem...battery indicator light not showing and battery not charging. We found out by accident that if the battery cover is open, it won't charge. So open the battery cover, open the USB cover, shut the battery cover and then plug in the USB as normal. It worked for us, hope it will work for you too.
