Toys R Us Tabeo Logo
A
Anonymous Posted on Aug 13, 2014
I'm locked out of my Tabeo tablet. How can I reset it?
My son put a password on his Tabeo Tablet and now we can't get it unlocked because he forgot it.
ken pullen
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Jan 08, 2016
ken pullen
Expert
Level 2:
Sergeant:
Answers
257
Questions
Helped
53421
Points
669
Go to you tube and type in hard reset a the brand and model and a page of videos that should help you sort your problem .
How do you reset the tabeo since my daughter forgot her pattern password?
Use a paperclip to gently press the reset button.
http://tabeo.support-tablet.com/tabeo-support
2answers
2answers
How do I unlock my tablet
If it's android then you can reset it but you will lose all the apps you installed along with any saved passwords.
power off the tablet by holding down power until screen goes blank.
hold both the power button and the volume up button for at least ten seconds.it should boot to android logo...then a robot with red exclamation.leave it alone until the option to reset screen appears.
follow onscreen instructions to reset.
How do I recover my lock screen password for my tabeo tablet
Not possible to recover your password just factory reset back to when new! Press power for 30 seconds then press power and volume+ buttons together until reset screen comes on then move to factory reset option using volume buttons and select using power button!
How do i reset tabeo 1 with out entering password
For factory resetting your Tabeo tablet, you have to go to 'settings' page. In this menu, youcan find an option for 'hard reset'. If you click or tap this menu, you can get a new optionswhere you will find option for hard reset. In this list, you can also find the option for hard resetting. If you select that option, the tablet will ask for confirmation.
Once you confirm, the tablet will perform factory resetting. Factory reset or hard reset will wipe of the data present on your tablet. So, it is very much necessary that you take back up of the data present on the tablet before heading for resetting. It is a good idea to keep the back up of all the files regularly so that you can go for hard resetting at any time, if the tablet gives any problem.
1helpful
2answers
Change pin number
hard reset by recovey options
4helpful
Tabeo reset pc unlock
If any problem arises in computer, we are habituated to format the PC. The same applies to laptops also. But when there is any problem in your tablet PC, there is no other option except factory resetting. It is similar to formatting. When your tablet gets infected with some virus, or when you got it locked accidentally, or if you feel that your tablet PC is running slow, you might have to go for hard resetting or factory resetting. You might opt for hard resetting due to various reasons, but theprocedure of resetting is similar in most of the tablets. First of all, when you are going for hard resetting of the tablet, you have to check whether the manufacturer of your tablet has mentioned any specialprocedure for it.
In most of the cases, the procedure will be same on all Android tablet, unless specified. You can check the official website of your tablet manufacturer or can also go through the manual book given at the time of purchase of the tablet. If nothing is specified, you can carry out the generalized process. For factory resetting your Tabeo tablet, you have to go to 'settings' page. In this menu, you can find an option for 'hard reset'. If you click or tap this menu, you can get a new options where you will find option for hard reset. In this list, you can also find the option for hard resetting. If you select that option, the tablet will ask for confirmation.
Once you confirm, the tablet will perform factory resetting. Factory reset or hard resetwill wipe of the data present on your tablet. So, it is very much necessary that you take back up of the data present on the tablet before heading for resetting. It is a good idea to keep the back up of all the files regularly so that you can go for hard resetting at any time, if the tablet gives any problem.
I need to factory default my tablet
If it is an apple tablet that has Icloud and find my ipad on you can log in to his icloud account and change the password at Icloud.com
Top Toys R Us Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Toys R Us Tablet and eReader Expert? Answer questions, earn points and help others
