Yes, i am trying to play 33's but it is noticeably fast. There is no belt only electronics and I'm not sure if there is an adjustment, or where I might find it.Yes, i am trying to play 33's but it is noticeably fast. There is no belt only electronics and I'm not sure if there is an adjustment, or where I might find it.
You can't post conmments that contain an email address.
Try MCM electronics - they have all size belts and the trick is to replace the stretched out belt with one that is about a quarter to one half inch longer in circumference.
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You, Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
there are no known software available... the software uses the drivers that comes with the software... the files that are downloaded from the recorder can be played in windows media player
I work at the History Channel and have a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
