Garden Logo
A
Anonymous Posted on Aug 12, 2014
What are the air and gas settings for a poulan micro XXV chain saw
The saw starts but dies out under cut and it will not stay running while idling
Ian Summerfield
Level 3:
Master:
  • Master 502 Answers
  • Posted on Aug 12, 2014
Ian Summerfield
Master
Level 3:
Master:
Answers
502
Questions
0
Helped
133848
Points
1385
Adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
3 Related Answers
Anonymous
  • 302 Answers
  • Posted on Aug 14, 2009
SOURCE: poulan micro xxv 25 yesterday i started the saw
i'll bet you have it flooded. Try a dry sparkplug. pull it over a few times with the plug out to help dry the cylinder out too
Anonymous
  • 110 Answers
  • Posted on Dec 19, 2009
SOURCE: i have poulan micro xxv chain not being oil when
wow thats an oldie, That saw uses a diaphragm pump located just above and in front of the clutch drum. Its going tobe hard to find one if its bad, Try cleaning out the oiler hole in the bar first, Then try running the saw without the bar and chain on and see if it pumps.Also check the oil pickup tube in the tank, It has a small screen on the end of it thats prone to sawdust clogging it. If it still does not oil then I suggest you locate the gasket and diaphragm for the pump before you take it apart. Remember to clean everything before reassembling,, Good luck
Anonymous
  • 6468 Answers
  • Posted on Sep 16, 2012
SOURCE: How does a Poulan Micro xxv get pressure to the chain oiler
there is a small oil pump behind the cltch
How does the oiler work on a poulan micro xxv
The oiler operates off the crankshaft under a cover behind the sprocket. Find the oil port near the back end of the guide bar where the oil pump injects the oil onto the chain. That port could be plugged. Your little Micro probably does not have an adjustable oiler but just in case invert the saw body and see if there is a + and - in the casting just under the sprocket. If so, moving the slotted adjustment towards the + increases oil flow.
Sometimes sawdust enters the tank when being filled and plugs up the inlet to the oil pump. Keep an old 1" paintbrush with your oil can so you can brush away the debris before opening the oil tank to fill while in the woods.
How do you adjust the carbrater on a poulan micro XXV chain saw
There should be two screws on the carb an air and fuel adjustment I always start by going all the way in then 3 full turns out and then work it a half turn each time until its right..
Aug 12, 2014 • Garden
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
4helpful
I have poulan micro xxv chain not being oil when
I have a Poulan 3314 saw that is only two weeks old. It works good until it's warmed up for about 20 minutes. Then, when you finish a cut and get off the throttle it dies. It always starts right up again....
The low side of carb setting needs to be shut down. Will speed the idle up and stop from overloading on fuel. Only one catch. It takes a special tool to adjust. Go to poulanpro.com for your nearest dealer.
1helpful
Poulan micro xxv 25 yesterday i started the saw ran fine.tryed today would not start.got gas and spark.loosenthe gas cap firer but would not stay running.thank you.
2answers
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Top Garden Experts
Jay Finke
Jay Finke
john h
