Televison & Video Logo
A
Anonymous Posted on Aug 12, 2014
Magnavox tv just flashes different colors tried to turn on the tv with the remote, but it didn't work. I pushed the power button on the tv and it turned on, but instead of getting anything, it just flashed colors. Red, to green, to blue to yellow, etc. I couldn't change any inputs or get the menu to show up. It would just flash a color on the entire screen for a couple of seconds and switch to a different color.
AAA TV Service
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Aug 15, 2014
AAA TV Service
Expert
Level 2:
Sergeant:
Answers
272
Questions
0
Helped
64861
Points
688
1 Related Answer
Anonymous
  • 5138 Answers
  • Posted on Jan 09, 2008
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Looking for a working remote code for a Magnavox/DVD TV combo (model MWC1305). Auto search not successful.
I'm not showing that we have a code for the Magnavox/DVD combo. I have provided the power scan instructions. Please let me know if you have already performed these steps. Thanks.
This is to program your DISH remote to your TV:PowerScan1.Turn the TV on2.Press and hold the TV POWER button for three seconds - The LED shouldflash3.Press the TV POWER button 4. Press the UP orDOWN arrow buttons on the remote (about one press per second). Stopas soon as the device turns off. -The TV should turn off5.Press # - Now addressed
1helpful
I need the code to set up my tv using at&t uverse remote, and the tv has no power button
  • Make sure that you have turned on the tv before you begin programing your Uverse remote control.
  • Hold down the TV button on the Uverse remote. (If you are trying to program a different device, hold down the button that names that device). As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
  • Find the 4 digit code for your device
  • At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. The manufacturer of your TV has many codes.
  • If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter.
    ---------------------------------------------- Sharp TV codes for at&t remote: 1004, 1009, 1011, 1025, 1064, 1077, 1078, 1081, 1097, 1099, 1153, 1157, 1274, 1298, 1311, 1312, 1362, 1375, 1378
    1helpful
    I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
    I suggest you try these steps..
    1.Turn the television set on by pressing the "Power" button on the set.
    2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
    3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
    4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
    5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
    I hope this helps...
    Viewsonic N2750w flashing different colors on screen
    did you get any answers? I have the same problem.
    1helpful
    1helpful
    Magnavox codes
    Try holding down the the code search button until the LED lights.. Then push the TV button.. with the tv on Start pushing the power button at one second intervals until the tv turns off.. Then push the enter button. that should find the correct code.
    4answers
    Big button remote rcr 4258
    does not have all the codes for every product,
    Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
    also goto www.replacementremotes.com (336)969-1842
    They will find you REPLACEMENT remote control CODES, not remote control
    2answers
    My 19" Magnavox won't come on.
    LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
    Top Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
