SOURCE: 2000 Mazda MPV Heating problem
The heater lines that run to the back of the right rear side gets rusty and start to leak anti-freeze. There is a black cover under and above the RR tire that has to be removed so u can see.
SOURCE: 2000 mazda mpv diagnostic box
There should be an OBD II plug under the dash on the drivers side. It might have a cover over it so look real close. That actron will give you generic P codes.
SOURCE: how do I replace alternator in mazda mpv 2000?
Typically an alternator is an easy fix. It requires removal of the belt from the engine running it, and a few bolts that attach it to the engine.
Because of the engineering with the 2000 mpv, it is a very difficult fix, and one that requires removal of the transaxle and exhaust manifold, as well as removal of the lower engine mounts. It will take a qualified Mazda mechanic 3.5 hours to do the fix - you can (at least) triple that amount of time as a DIY project (assuming you have the right tools).
SOURCE: My 2000 Mazda MPV heater fan works for 4 not for 1
You need to replace the blower motor resistor,it's in the heater box.Number 4 bypasses the resistor and all the other speeds go through it so it's the most likely problem.
