We recently upgraded our Nortel Phone system (not the receivers, but the actual hardware for the system. The company that came in to do the upgrade had to re-set the receives) Our voicemail is housed by the Telus, our phone provider. Previously my phone would display if there were messages waiting on the Telus voicemail system (as line 1 will have a different dial tone when there are messages waiting). I have been through the admin features on the Nortel T7316 and thus far am not able to find a feature set hat will re-activate my ability t have the "msg" indicator display on the screen. Doe anyone know what to do in order to have this feature re-enabled? Thank You,
SOURCE: inactive features
Is the phone system working but the voicemail did not come back up ? Can you tell me what kind of voicemail you have, ist should be marked on the voicemail system ?
SOURCE: Phone automatically activates call waiting feature.
Toss it in the dumpster No see if there is an auto answer option . Check and see if the (DELETE TRANSFER BUTTON ) is pushed in i just tested the exact phone and it makes it answer right away when the call comes in . See if perhaps your chin or hand is holding this particular button down
Good luck
~Rick~
SOURCE: how do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
SOURCE: We have a Panasonic KX-T7633 phone system and the
The voicemail system has a Class of Service option to delete or forward messages that are left on the system. If you set it to delete all heard messages (old message) or unheard messages after X days, it will delete them. You can move mailboxes into different classes of service so they have variable expire times.
Carl
Dear Annabelle,
Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards;
Ahmed Safaa El-DeebTelecom & Network Engineer
