Kenwood KDC-MP235 CD Player Logo
S
Sandi Posted on Aug 12, 2014
Jammed cd I just purchased a 2003 ford mustang and I just try to take out 4 of my cd's and they will not eject. what can I do?
Where are the radio fuses for my 2006 for mustang gt...even since the car was new the shaker 500 has had issues...the cds get jammed and the cd player says error and wont eject the cd
There could be two fuses that service the radio; one identified as 'Accessories' in the main fuse box and possibly a second in-line fuse inserted in the 12V line and under the dashboard.
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Stereo in 2001 Mustang Bullit
you probley have two cds jamed in there if you can here the motor trying to eject the cd and bogging out. or if you can here the eject motor running smoth and nothing coming out the gears are broke. you will have to pull the deck out and dismantel if you want the cd back.
1helpful
Cd in car player will NOT eject -any ideas ??
The only way to fix your problem is to have a radio repair shop take it apart. You cannot fix this on your own. Remove the radio or get a quote from a repair shop first. If you cannot find a repair shop , talk to the parts guys at you local ford dealer about sending it out for repair.
1helpful
I have a 6 cd changer in my 2003 ford mustang, when i try to push the cd buttons i get cd error. the opening will not close and i cannot sel buttons for my radio to change the station but i can use the...
i have a 2002 mustang and my radio did the same thing. when i went to load or eject it would say cd error or no cd. then when i would select load cd, it would say slots full. i had someone unplug the positive cable on my battery and let it sit for a few hours to reset. then when it was hoooked back up and i started my car, the cd player started working again.
2answers
Cd player
My CD player jammed while testing it during my test drive (2001 GT), and they offered to replace it.
I found out that all of them do it. When I eject my disc, and it jams. If you look into the slot, you can see the cd. It is just not quite aligned right. Use your fingers to tap (as hard as you can) on the front of the deck. It should knock the cd loose, and it will come out. Works every time for me. Don't wait for the error to come up, as soon as you notice it didn't come out, do it, and it should eject just fine.
1helpful
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
