The swivel base has become loose and the actual set is very unstable how can I fix it?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs are given with illustrations. You can get details from it.
SOURCE: LG swivel base
Just look at where the base goes in. There should be 4 screws that are holding it on.
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
SOURCE: Panasonic Viera missing the red color spectrum?
Ours is doing the exact same thing! I came here hoping to find an answer. Did you figure your tv out?
SOURCE: The Swivel Mount TV Stand
There are different types of stands as well as the screws vary. It is by the exact type of stand we can provide a screw size.
Another solution is for you to try to reach the dealer that supplied the TV stand to you, so as to get the exact screws that came with the stand.
Take care and good luck
