Home Logo
A
Anonymous Posted on Aug 12, 2014
1.6 toilet will not fill - American Standard Home
A
Anonymous
Make sure the water valve to the toilet is actually letting water into the fill valve. Turn off valve, remove from fill valve, run water into a pan to see pressure and confirm water flow. If water flow and pressure good, replace the fill valve.
Water supply to toilet fills up tank too slowly
Valve fully open on inlet going into toilet if it is then fill valve needs to be replaced check water line for any abstructions that might interfere with water going into tank.
Apr 02, 2014 • Kohler Home
Uberhaus toilet fill valve will not open to let tank fill
Maybe something wrong with the mechanism inside the toilet fill valve. Try to adjust the fill valve first. I found this one about adjusting fill valve, I hope it can help you.
ADJUST MOEN TOILET FILL VALVE 5300 Home
If the problem remain after adjusting the fill valve then I will suggest you to buy a new toilet fill valve and replace with the old one.
Thanks.
Oct 06, 2013 • Home
Toilet does not stop filling, water keeps running
Replace your toilet fill valve with a fluidmaster 400A
Click here
http://411plumb.com/how-to-replace-your-toilet-fill-valve-with-a-fluidmaster-400a
heatman101
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this...
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
1helpful
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 • Home
Toilet fills up slowly
buy a universal fill valve and replace it
Jan 03, 2009 • Home
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
