SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION SPECIFICATION FUEL TANK
All Models
76L (20 U.S. Gallons)*
ENGINE OIL
3.0L Diesel with Filter (10.0 Quarts)
3.7L with Filter (5.0 Quarts)
4.7L with Filter (6.0 Quarts)
5.7L with Filter (7.0 Quarts)
6.1L with Filter (7.0 Quarts)
COOLING SYSTEM
3.0L Diesel
13.2L (14.0 Quarts)
3.7L (9 Quarts)**
4.7L (14.5 Quarts)**
5.7L (14.5 Quarts)**
6.1L (14.8 Quarts)**
A/C REFRIGERANT SYSTEM
All Models
0.68 kg (1.5 Pounds)
POWER STEERING SYSTEM
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 545RFE
2WD 5.2 L (11 Pints)
4WD 6.2 L (13 Pints)
Service Fill - NAG1
5.0L (10.6 Pints)
Overhaul Fill - 545RFE
13.33L (28.0 Pints)
Overhaul Fill - NAG1
7.7L (16.3 Pints)
TRANSFER CASE
NV140 and NV146
0.65L (1.4 Pints)
NV245
1.8L (3.8 Pints)
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
