Was the Operating System installed by the manufacturer, or did you reinstall it? YOu probably just need to go to the compaq web site, and download the appropriate driver for the integrated card reader: http://www.compaq.com/country/cpq_support.html
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
hi did you get the resistor fixed if not you need to remove the glove box by removing the screws that can be seen then there are two plastic lugs that need to be pulled out sideways to enable you to remove the glove box then you will see the resistor card on the side of the motor thats on the new shape micra k12
I have not used my nissan micra 2003 for 7 months it has been stored in the garage but the engine has been started on a weekly basis but today the warning engine light has come on, the car has only done 2300 miles, SHOULD I BE WORRIED or is it because the battery has been disconnected in between starting the engine so it didnt drain the battery while it was standing in the garage unused, this has happened the day before i take it for a mot.....
