SOURCE: The jets on my aker
could be a few things ---
1. it could be the on/off switch.
2. it could be a loose wire.
3. it could be a bad motor.
4. it could be a blown fuse or a bad breaker at the panel.
c...
SOURCE: Aker Swirlbath. on/off
1. Whirlpool does not
start/stop.
A. No power to pump motor. A. Set/Reset GFCI breaker; check
wiring. If problem persists, refer to
installer/dealer.
B. Faulty air switch in pump motor. B. Replace air switch in pump motor.
Refer to installer/dealer.
C. Faulty air actuator. C. Replace air actuator. Refer to
installer/dealer.
D. Air actuator tubing disconnected,
loose, kinked, plugged, or damaged.
D. Connect, tighten, straighten, clean, or
replace air actuator tubing. Refer to
installer/dealer.
E. Faulty pump/motor. E. Repair or replace pump/motor. Refer
As you can see from this.... there are a few things that can cause this...
the most likely is the air switch...but check the tubing for cracks and kinks first....
heatman101
