Question about NorStar T7208 Corded Phone
How do I remove Denied in Admin from a Nortel phone handset t7208
    New Friend:
  • 49 Answers
What's the feature you/user was trying to access? Some features are automatically forbidden for everyone except admin. Check the user manual: Nortel networks phone manual t7208
Posted on Oct 06, 2015
  • 108 Answers
It's not so much removing Denied in Admin as it is enabling whatever feature the user was trying to access at that set.
Which was... ?
Posted on Oct 06, 2014
SOURCE:
consultel1
  • 860 Answers
SOURCE: How do you change names on a Nortel T7316 phone?
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Posted on May 07, 2010
SOURCE: caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Posted on Sep 21, 2008
SOURCE: i cannot remove do not disturb
Feature 69 is priority call.
Feature 85 is DND
To cancel a feature you need to insert a "#" before teh feature number, example:
to cancel DND:
press feature"#85"
Posted on Jan 03, 2009
  • 183 Answers
SOURCE: Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Posted on Feb 09, 2010
consultel1
  • 860 Answers
SOURCE: cant change time and date on nortel t7208 phone
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Posted on Apr 15, 2010
Testimonial: "With clarification that I gave on steps I took and what were results within three questions figured out the problem and solved it. Thank you very muc"
You don't. Only the administrator who set that restriction can undo it.
Mar 11, 2011 | Nortel T7316E 2-Line Corded Phone
How do I change the time on my BT T7208 telephone (Nortel Network).
1. Press Feature x x 8463 (x x TIME) you should have Password displayed on your telephone.
2. Enter 22742 (BASIC) or 23646 (ADMIN) you now should have Hour on your display.
3. Now press Change and enter the correct hours using the key pad
4. Press NEXT and you should have Minutes displayed on your telephone, now press CHANGE and enter the correct Minutes.
5. Press NEXT and you should have Year displayed on your telephone, now press CHANGE and enter the correct Year.
6. Press NEXT and you should have Month displayed on your telephone, now press CHANGE and enter the correct Month.
7. Press NEXT and you should have Day displayed on your telephone, now press CHANGE and enter the correct Day.
8. Now you will have ---End of List--- displayed on your screen, you can now press Rls or handset down button to come out of programming.
Feb 28, 2011 | Nortel Business Series Terminal T7208 -...
I have a Nortel T7208 phone. It shows "Message fo...
I have a Nortel T7208 phone. It shows "message for you" and the light is on but when I open my vm. I don not have a message how do I get rid of this?
May 19, 2010 | Lands Phones
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Sep 30, 2009 | Nortel Business Series Terminal T7208 -...
Handset does not work, only handsfree, how to reset on T7208
Check the bottom of the set, and make sure that the handset is plugged into the handset - not - handset to the headset jack.
Make sure that the cords that attach the handset are all plugged in.
Take someone elses handset and test to see if it the set or maybe you have a bad handset issue.
Good Luck
Aug 10, 2009 | Nortel Business Series Terminal T7208 -...
I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
May 18, 2009 | Nortel Business Series Terminal T7208 -...
How can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
Apr 17, 2008 | Nortel Business Series Terminal T7208 -...
Password
Admin password for what? Voicemail? Phone system admin?
Dec 27, 2007 | NorStar T7208 Corded Phone
NorStar T7208 Corded Phone Logo
3,884 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
