I am trying to install Windows Server 2008 R2 on a Dell PowerEdge SC1420. The server uses the Adaptec CERC SATA1.5/6ch array controller. Dell has drivers that can be downloaded, but the file requires two floppies. I do not have any floppies or a floppy drive. I have tried several virtual floppy drives but none of them will work with the Dell file. I am looking for the actual files that Windows Server 2008 requires to see the array controller.
OK, EZPZ.
These drivers will install when you first start installing windows 2008 server. You'll see a option that says: Hit F4 for any further drivers needed for windows to install. I think it's F4. You can place these drivers on a thumb drive OR a CD - you must extract the files on to a thumb drive. At the very start of the windows install you'll see the option for additional drivers.
First screen - Success
SCSI - Yes, that is correct. Correct, but ThHow can I find the Windows Server 2008 driver file - 24930663-deewisxuy4wetc5wzbekciyz-2-3.jpg"/uploads/images/24930663-deewisxuy4wetc5wzbekciyz-2-3.jpg" alt="24930663-deewisxuy4wetc5wzbekciyz-2-3.jpg" class="h_miHow can I find the Windows Server 2008 driver file - 24930663-deewisxuy4wetc5wzbekciyz-2-6.jpgom Dell, on the disk, you won't get...
This screen. This screen means that windows could not find any driver for your drive and there for, you must start over - Same steps.
But make sure you choose the correct driver - you might have to try a few that are in the list.
Greatest of luck - EZPZ
Have a great night..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
SOURCE: Problem
This server direct not boot by windows cd....
and u any time install window u lose the all data....because they have scsi hard drive and configuring bydefault Raid 5 ......so plz make backup before u start this prosiger.......Dell providing u lots of cd's check it this cd "installation and server management" bootable cd put this cd into your cd rom drive...and i am giving u link that how to complete install window in this server.
http://rapidshare.com/files/175988908/how_to_install__os_-_window_storage.doc.html
SOURCE: Hello. I got a Dell PowerEdge
The series of Intel Xeons associated with thethe E5430 is starting to become outdated, and thus it is difficult to obtain them. Memory4Less is selling the exact same processor as the one you have for $860 (can be found here: http://bit.ly/i46z9h ). Unfortunately, it does not come with a heatsink or fan. It is very difficult to find the original fan for a processor sold on its own. While you may not be able to find an original cooler, many companies have made heatsinks that are compatible with Socket LGA771, which is the same socket your processor uses. A comprehensive list can be found here: http://bit.ly/dOzByw A concern when having to use a fan that did not come standard with the CPU is whether or not it will fit in the case. Take careful measurements, and use the fan for the processor you already have as a point of reference. If you absolutely must have the original Dell fan, then I wish you best of luck with your search.
Testimonial: "Thanks a lot! Very helpful!"
