My KX-TG47458 and 5 handsets no longer have a working caller ID and I need to know how to reset that feature.
That is not a recognized model number. They are usually in the format ending with 4 numbers and a letter: e.g. KX-TG7643M. Check your model number (is the 8 a "B") and search the Panasonic site for the manual: Panasonic Product Support
http://shop.panasonic.com/support/?selectedTopNavId=nav10&support=y
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
SOURCE: This is really silly, but
HOLD DOWN the "M" key which is the "*" key in the bottom left for 3 seconds until you hear a beep. Repeat if you want mute again.
Jack
This feature lets you know who is calling
without looking at the display.
To use this feature, you must:
- subscribe to a Caller ID service of
your service provider/telephone
company.
- turn this feature on (page 24).
When caller information is received, the
handsets and base unit announce the
caller's name or phone number received
from your service provider/telephone
company following every ring.
The unit announces in English only.
L Name pronunciation may vary. This
feature may not pronounce all names
correctly.
L Caller ID service has a limit of how
many characters can be displayed. If
the caller's name is too long, the
handset may not be able to display or
announce the entire name.
L The announcement is heard at the
same level as the ringer volume (page
16, 23).
L If you turn on the answering system
and set the number of rings "2
rings" (page 36), the unit does not
announce the caller information. If
"Toll saver" is selected and there
is a new message, the unit does not
