I have a problem with hp m1005mfp an error is load tray 1
1, Read the specification document and learn what the paper sizes are compatible with the printer. Load the papers and adjust them using the paper width guides.
2, Make sure you are using appropriate paper type, for example, if you are printing a photo, load the photo sheets into the input tray.
3, Also, make sure, you mention the right paper settings in the Printer Settings page. By following the guidelines, you can avoid this issue.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
SOURCE: HP Laserjet 4000 Error
It is asking for an envelope. Check your page setup and/or your tray configuration. Also make sure your paper stops in the tray is set at the type of paper it is for.
SOURCE: when i print it defaults to tray manual feed. i
change paper size setting on printer preferences on your pc
SOURCE: my new hp 2035n printer
Instructions
Things You'll Need:
Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer. Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation. Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly. Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on. Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit. Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far. Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too. Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual. Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
SOURCE: hp laserjet m1005mfp scanner error
Hi there and welcome to Fixya!
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
This error message is usually fatal so if the problem persists after trying the steps above, you will need to contact the manufacturer for further assistance. Please refer to the manual that came with the printer for contact information.
Thanks!
SOURCE: i have p3005n hp laserjet
Check tray2 sensor flag located beside of pick up roller, if its strucked try to shoot it
