I have a 50' TV tower w/ new antenna. When 1st hooked up (solid), I received channels from 2 thru 66-2 (most anyway). We had a tornado, but my antenna was checked & assured not turned nor any wires loose. Now I only get channels 7's, 11'l, 50's & 56's. I have scanned, unplugged, but never hit the 'reset' button on remote. Is it safe to do so?? What should I do next??
Tuner fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
SOURCE: I have sanyo tv with
Try some new batteries in the remote, or, just roll the batteries in the holder.
SOURCE: my sanyo tv doesn't have an input button, neither
yes, using the channel selector go down below channel 2 and see what happens. input 1 input 2
