How do I reset a zeepad 7.0 back to factory settings?
My son set a pattern lock on his zeepad and the wrong pattern was entered too many times. Now it is asking for the gmail address and password to unlock it, But it will not accept the info now. I know the email and password are correct as it is linked with other devices. The password was not changed before or after the tablet locked. I have tried the factory reset but it seems the drivers are missing for that. How can I unlock or even reset this tablet. I'm aware that I could lose any and all data on the device.
If it's invalid, it's more than likely you got your google account wrong, check on your computer and if it still doesn't work try to reset your password, or simply start a new google account.
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here... http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
Try this before you do a factory reset by loading the firmware again.
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Support Troubleshooting Guide
