Can you provide more detail on this? Such as under what conditions it overloads, and how much power you're drawing off of it? Keep in mind that generators have two ratings: Sustained Load and Peak Load. Mine, for example, can handle a sustained load of 1,750 watts, and can handle short-term peak loads of 2,000 watts. Note also that if you're running a microwave, they take a lot. So does anything with a motor in it (refrigerator, etc) on initial start up. Once you've added up all your loads, adjust to where you're within your generator's sustained load and you should be fine.
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
sounds like either something is shorted out or the governor is stuck. Check the governor linkage to start with and make sure it is free. Then check the push in breakers for the outlets to see if they are popped. If not the brushes or the armature could be stuck or corroded.
