You can change to any bit, but have to change the compression collar inside the end of the shaft. For example if the tool shaft size is 1/8" you need to use the 1/8" collar etc. Make sure you use the corresponding bit with the corresponding compression shaft size or the bit will not lock in position when you tighten the collar.
