Microsoft Picture It! Photo version 7 in Vista will not create a project. Script error when create a birthday or any other card. Application Stops working. Here is the report:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Pip.exe
Application Version: 7.0.716.0
Application Timestamp: 3d34b87a
Fault Module Name: unknown
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 206e7572
OS Version: 6.0.6002.2.2.0.768.2
Locale ID: 1033
Additional information about the problem:
LCID: 1033
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
From researching this it is caused by having too much ram .
There was a patch called pi19299.exe on microsoft that fixed this bug but it seems to not be supported anymore on microsoft as it was for windows xp and whether it works on vista is not a certainty .
https://answers.microsoft.com/en-us/windows/forum/windows_xp-pictures/where-do-i-find-patch-for-19299-download-looked/028dae22-4427-4dba-8612-da7daa25a176
https://www.cnet.com/forums/discussions/microsoft-picture-it-2002-crash-patch-for-xp-only-301075/
SOURCE: same exact problem
What you need to do is to reinstall the Internet Explorer 7. Go to the control panel and click on add/remove programs. Look for Windows Internet explorer 7 and remove it. Download the Internet explorer 7 from www.microsoft.com and search for Internet explorer 7
SOURCE: I want a program like microsoft
The latest and last version of Digital Image Suite
would be the current replacement for Picture It!.
"Microsoft Digital Image Suite Anniversary Edition"
This software line has been discontinued but some
retails stores could still have copies for sale. Also
check on eBay for availability.
There's a 60 day trial available for
download if you would like to give it a try:
Starter Edition 2006
http://tinyurl.com/28loxr
(this product line has been
discontinued but you can still
down-load the Starter Version
and run it for 60 days)
Unlike the retail version...the trial does not
have the ability to create VCDs and it does
not include the clipart and pre-formatted
projects.
SOURCE: APPCRASH.
Use total uninstaller to uninstall it then reinstall it again
Please VOTE 4 ME for better attention
SOURCE: Problem signature: Problem Event
Try this
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
