Microwave Ovens Logo
A
Anonymous Posted on Aug 10, 2014
My friend bought me a Magic Chef Model # MCD1811ST Microwave Oven and opened the box plugged in (should a light come on when you open the door, because this does not) no light. What now?
It's new just taken out of the box, repeat. My friend bought me a Magic Chef Model # MCD1811ST Microwave Oven and opened the box plugged in (should a light come on when you open the door, because this does not) no light. What now?
william rodriguez
Level 3:
  • Master 958 Answers
  • Posted on Aug 10, 2014
william rodriguez
Master
Level 3:
Answers
958
Questions
Helped
169861
Points
2511
Does the unit work? if it does then the light might be blown or broken the owners manual will tell you how to change it.
5 Related Answers
Anonymous
  • Posted on Jun 27, 2008
SOURCE: Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 27, 2008
SOURCE: Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 29, 2009
SOURCE: The light is off on my Magic Chef MCD11E3W
Since the owner's manual doesn't cover it, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Mar 01, 2010
SOURCE: blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 06, 2010
SOURCE: I need to replace the door handle on my Magic Chef
You can order that and other parts here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
Magic chef microwave keypad not work model microwave hmd1110W
That would be a failed keypad, but the part is no longer available.
- Ed Miller
http://www.microwavecontrol.com
My magic chef microwave won't come back on, model MCD99R and it's 4 yrs old
Your oven has a plug or is wired to a 120volt line. Check this. You may need to Reset circuit breaker.
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
2answers
My Magic Chef microwave oven blows fuse when i open door
If you're blowing fuses from opening the door that is the sign of a electrical short . You'll need to call a electrician to check it out. Changing the fuse in this unit can kill you. There's a capacitor that holds stored electrical energy that is dangerous. My good friend died from trying to change the fuse in his. Get a professional to check it.
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Magic Chef Microwave has stopped working. None of the buttons work. It's showing random numbers when you plug it in. I tried a different outlet and it gave me different numbers.
Try unplugging it for 24 hours. Plug it back in and see if this helped. If it's still the same, it needs a new control PCB (printed circuit board).
How to set the clock on a Magic Chef Microwave
Google the model number with "manual" or user manual or visit the Magic Chef site and search there--pretty sure if you call them they can either mail you the same or show you how to get it on their site.
Hello, We received a Magic Chef Microwave Oven, MCD1110WB / MCD1110BB yesterday (8/31/11) to use in our workplace kitchenette. We are accustomed to having the microwave light come on when any...
We have the same oven, and the light comes on only when the oven is operating. When the door is open, the light is not on. I would be interested in knowing if anyone has done a work-around to make the light come on when the door is open.
Blowing fuse when opening microwave door
Microwave oven not functioning
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
