Phone rings but doesn't connect
Please refer user guide available at the attached link.
I am assuming you have trouble answering incoming landline calls from the phone and there is no problem with making outgoing calls on landline. Also I am assuming you are using cell phones and do not have any panasonic handsets.
First thing to check is whether you can answer using the base unit or not. From there on you will have to then check if the cell units are actually working with the base unit. Follow the bluetooth setup instructions and make sure your cell phone is compatible.etc. http://service.us.panasonic.com/opermanpdf/KXTGE260-MUL.pdf
SOURCE: KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
SOURCE: Does not know how to delete calls
If you are talking about the answering machine, typically, the erase button deletes tha last call, and a second tap erases all stored messages.
If you no longer have the user guide, you can download it here:
http://www.generalmanual.com/down.php?link=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tYVEcxMDMyLnBkZg%3D%3D
