i think you need audio video switcher like this at the bottom usually the cable is using only the RCA the one with color red,white for audio and yellow for the video.
Can I connect my Nintendo to my Cable Box, my DVD, or my VCP (video cassette player)? Your Nintendo system requires AV inputs to work. These products do not provide inputs. Connecting to them is not possible. Unless you get a blue plug for it to work then with the connection then.
try connecting a 9volt battery with a couple of jumper wires to the correct terminals on the battery for about 30 seconds then put it on charge(positve to positive negative to negative) if the battery is to low the charger won't pick it up and start the charging cycle by connecting the 9volt to it t will put a small charge to it to start the charger
okay.. (in case this is the problem) the yellow jack goes into the video slot, and the white and red jacks go into the audio slots.. (it wont matter wich one you plug it into)
if thats not it, then maybe take your ps3 back and get a new one
get a test light, 12v remove the tail light from one side. identify each wire by turning each light on . and connecting the test light to see wich one becomes active remember to connect your test light to a good earth attache each cable one by one the final indicator will be on the other side you will need to run a single wire accross to that side (unless the wiring loom passes one side) make sure you connect them properly and tape them to avoid problems later soldering is best.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
You will need what is called an RF modulator. What this device does is to take the place of the internal mod that Used to be included on old VCR/DVDs....accordianman
