SOURCE: What format do video files have to be in to work
Your player supports the MTV file format, 128x160, 25fps...
You can download a converter from here.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
SOURCE: deleted software on coby mp620-8g
Hi, 2 Find and click the Sync tab. This is located at the very top of the program. 3 Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player. 4 Click Library. This link will be on the left side of the program. 5 Double-click the Songs option in the middle of the screen. 6 Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select Add to Sync List. You will then notice the song listed in the column located on the right side of the program. 7 Repeat the previous step until you're finished putting songs on the Coby mp3 player. 8 Click the Start Sync tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player. You can also use the Frequently Ask Questions of Coby. Click Here and you can also download the driver and documentation here. Just make sure you select the make and model of your MP3 player Thanks for using Fixya.
Welcome to Fixya. If you deleted the software on your mp3 player you can still load music files by following the instructions below.
1 Open Windows Media Player.
SOURCE: How do you put a video on the Coby MP620 [4 GB]
You can put a video on the device using "Coby Media Manager". To install it:
1. Plug your device into the computer
2. When the Autoplay menu appears, select "Open Folder to View". If no Autoplay menu appears, then look for the device in My Computer.
3. Launch the "coby-cometlite.exe" file and follow the setup instructions.
4. Now you should be able to use "Coby Media Manager" to automatically convert and transfer videos to the device,
SOURCE: how do i put music
MP3 players can only play music files in mp3 file format.
You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
SOURCE: I am having problems getting
At first try to reset the player (use a paper clip to gently press the Reset button on the rear of the player) .
If this can not fix the problem you should recover or upgrade the firmware. Connect it to the PC and run the Coby manager software and try to find the these possibilities within this application.
Thanks.
gylacz
