How do i remove fix code when i go to zone 2.
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
I’m happy to help further over the phone at https://www.6ya.com/expert/glenn_3b3dd885737c06f6
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX"
1. Press "Amp" button (right side of remote - 1/3 way down)
2. Press "Menu" button (center of remote - 1/2 way down)
3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver
4. Press "Enter" button (green letters)
5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver
6. Press "Enter" button (green letters)
7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver
8. Navigate from there
Hope it helps. It worked for us.
SOURCE: volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
SOURCE: zone 2 issues
SOURCE: zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on
setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal
power amp.
Setting the RX-V661 remote control to operate Zone 2
1.
Using a ballpoint pen or similar object and press the Code set
button.
The Transmit indicator on the remote should flash twice.
2. Using the
numerical key pad on the remote and key in 9992, the
Transmit indicator
should flash.
You will now need to assign the receivers internal amp for
Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the
Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter
button.
5. Arrow to the Sound Menu option and press Enter.
6. In the
Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP
ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return
to the Manual
Setup.
SOURCE: zone 2
If you are using an external amp, "fixed" is what you will see on the Yamaha's display when you want to change the volume. If you are using the power of the Yamaha's Zone 2 outputs, you need to go into the "Menu" then "Manual Settings" then "Options or Zone 2" and set it for "Int" That will solve your problem.
