Not draining nd on display pipes clear
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
SOURCE: how to replace the drain hose on amana washer
no sounds like stand pipe is blocked somewhere remove and clean probably blocked with limescale
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
SOURCE: My amana front load washer
The ND error code means NO DRAIN, why it comes up is because the computer thinks that within the normal times it takes to drain the water from the tub it hasnt drained in that time.
Things that will cause it to not drain in the normal time is oversudsing becuase too much detergent was added.
Or something such as lint in the drain pump filter screen restricting the water flow into the pump
Gene
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. NF error in your Maytag is displayed due to no fill
condition, when the washer tries to fill but is unable to, nf is displayed.
Please check the water inlet valve for any clogs and obstructions, you can also
clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
