What does er 1f mean
SOURCE: LG Model LFX25960 has error
Turn off the switch for the icemaker, then flip the circuit breaker to off for a few seconds and turn it back on. The display should remain lit and operable, but you won't have an icemaker. See service manual pg. 32: http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
LG=JUNK!
SOURCE: LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service
Manual
"ER IF" show a problem with the ice maker fan motor.
SOURCE: ER 1F
It is ER IF and indicates that the ice maker fan is not working. The fan is probably frozen. If you can remove the fan duct and housing at the back of the freezer you may be able to defrost the ice in the fan enclosure. The fan may have frozen because of hight humidity or because the defrost cycle is not working.
