Dryers Logo
A
Anonymous Posted on Aug 09, 2014
E64 error code electrolux dryer
What does e64 error code mean
Dado
Level 3:
Master:
  • Electrolux Master 511 Answers
  • Posted on Oct 17, 2015
Dado
Electrolux Master
Level 3:
Master:
Answers
511
Questions
0
Helped
482382
Points
1313
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
4 Related Answers
protek480
Craig Butler
  • 1730 Answers
  • Posted on Sep 25, 2009
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 4323 Answers
  • Posted on Sep 13, 2010
SOURCE: I was drying and the
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Anonymous
  • Posted on Dec 18, 2011
SOURCE: error code on a Frigidaire affinity dryer E64
Heating element wire malfunction.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 21, 2012
SOURCE: frigidaire affinity electric dryer says error E 64, what does that mean?
Heater has an open circuit and need to be replaced. Here is the part you need.
2answers
Error code e64 dryer Electrolux FFSE5115PW2
How to Fix Electrolux Dryer Error Code E64
Appliance Express https://applianceexpresstx.com > News and Tips
Apr 10, 2023 - If your Electrolux dryer is showing an E64 error code, this means there is a problem with the heating circuit. When this occurs, your dryer ...
Common Electrolux Dryer Error Codes & How to Fix Them
Just-in Time Appliance Repair https://justintimeappliance.com > blog > common-elect...
Feb 3, 2020 - Another of the more common Electrolux dryer error codes, E64 indicates a malfunction with the heater's wiring or the heating element itself.
How To Fix Frigidaire & Electrolux Dryer Error Code E63 E64
howtofixit.net https://howtofixit.net > how-to-fix-frigidaire-electrolu...
Oct 18, 2020 - These E63 or E64 error codes generally mean that you have an issue with the heating element ...
Videos for E64 Error.
How do I get rid of code? I have an Electrolux front load dryer model #EIMED55IIWO, with E 64 error code. When initially starting the dryer I cancel the code and start the dryer.
E64 error code Electrolux dryer! E64 fault code on your home Electrolux clothes dryer. What this code stands for is that you have a shorted heating element. Other Possible fault: Heater thermostat faulty: Wiring faulty; Electronic board faulty.
https://advancedappliancesolutions.com/e64-error-code-electrolux-clothes-dryer/
https://www.youtube.com/watch?v=ErDSsjVywwg
2answers
What is an e64 error code on electrolux dryer ewmed70jss?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
5helpful
E64 code eletrolux dryer
Hello cordiapartin - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for an open circuit. Depending on the diagnosis's, the heater might need replacing and/or wiring
1helpful
E64 error code
Hi gordsxbstn34 - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
7helpful
Error code e64
Hello Gary Melton - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
3helpful
We are getting an error code 64. What do we do to fix this
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and cancel. Hope this helped Tim
21helpful
2answers
Getting a fault/error code E 64
Error code E64 means heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and ?cancel?
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
