Electrolux Frigidaire Affinity AGQ8700FE Dryer Logo
Micheal Herrick Posted on Aug 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix so it turns on and drys instead of humming and Pausing
When the power is on the dryer buzzes when you push start and that is it.
Ryan Pries
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Aug 10, 2014
Ryan Pries
Expert
Level 2:
Sergeant:
Answers
257
Questions
0
Helped
69350
Points
791
If the dryer is I humming but the drum is not turning then the motor is turning but the belt is not attached, it is probably broken and needs a new belt. if your belt is intact then your motor or start capacitor is bad.
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 • GE Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
My kenmore dryer makes a buzzing noise when I push the on button and will not turn on.
When you press the push to start switch and you hear a buzzing/humming sound, it is the motor that has gone bad and CANNOT come on. PLEASE check the motor to see that IN FACT it is bad and that there is NOT SOMETHING foreign somwhere in the blower wheel or elsewhere stopping the system from freely turning
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 • Dryers
1helpful
Dryer won't start but makes a humming / buzzing noise when you push the start button
If the humming noise is coming from the motor, (take the back panel off) remove the power plug and try to turn the motor by hand. If it seems free, look for a 'starter' capacitor on the motor which may be bad.
Oct 11, 2009 • Dryers
When I push the start button, the unit just buzzes or hums.
You have a broken drum belt. The hum you hear is the motor spinning at high speed.
1helpful
Just buzzes
 the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
