HOW do I install my Pioneer 4 channel power amplifier GM X 84 along with my pioneer DEH-17 cs player .? A wiring diagram is needed
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
SOURCE: Wiring diagram for Pioneer DEH-P6550
black is negative blue is remote red is accesory key switch yellow is constant power memory,gray with black is RF negative and gray is positive white is LF positive and white black is LF negative.violet is RR positive and violet black is negative and green is LR positive and green black is negative
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
