How to fix no upper tension? I took the machine to a local sewing machine shop and they can't frigure out why there is not any upper tension and would like to know if I replace the thread cartrage if that would fix the problem or if it is something else?
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
SOURCE: I have a Brother SE-270D. The top thread is not
A bent needle will cause this. Otherwise the shuttle is out of time, have it serviced..
Testimonial: "Thank you! That is exactly what I ended up having done."
SOURCE: brother embroidery machine broken
Mine was doing the same thing, it wasn't threading right. The thing that pulls the thread down to the needle was out of place, and it wasn't wrapping the thread around the tension. Hope this helps!
