Audiosonic 807f set top box tested o.k to other tvs using composite output but NEC tv doesn't receive signal,how do i tune to set top box signal
SOURCE: NEC 42mpi plasma tv not working
Check the +170 volt test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
SOURCE: Tv stand required for obsolete model
I have one I bought new. We are hanging the monitor on the wall. Paid $300 for stand, will take $150
SOURCE: Nec Plasmasycnc 50mp2 RGB1
The problem was that we did not have the manual for the TV. The owner was playing with the TV and sele cted the picture within a picture option. This was what we attempted to use to view the image.
I finally got to the full screen and everything worked fine.
Homer
SOURCE: i have nec plasma px-42vrjg dont know how to wire
I think you mean sky as in sat service as we have this in Mexico whats going on here is this Tv has two tuners and hte reason for no signal is in some area channel 3 is and has programs on it causing htis interfearance so what you can do is this hook the sky box on the yellow red and whit plugs ( I hope you know what I mean) There call RCA for short and this will shore this up but make sure you put your TV on the channel with the inputs hope this helps you out
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
