If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
SOURCE: i need an owners manual for a chicago electric generator
ago electric Generator Manuals\r\n
The Harbor Freight web site has PDFs for most of these generators. Go to.
http://manuals.harborfreight.com/manuals/XX000-XX999/XXXXX.pdf
Replace the first two XXs with the first two digits of the model number, and the last XXXXX with the model number.
For example, the manual for model 65414 would be on the following page.
http://manuals.harborfreight.com/manuals/65000-65999/65414.pdf
