How do I clear frequent calls from the Kyocera hydro phone?
If you are already on the "frequently called" list, look in the lower right corner. There is a symbol that looks like 3 gray boxes stacked vertically. Press that and a menu will appear. The third item down in that menu is "clear frequents". Press that and you should be good to go.
To get to your "frequently called" list, from your home screen press the green phone symbol on the bottom left. From there, look at the menu at the top (gray phone, gray clock, gray person) and press the gray person symbol. You should now have an aqua heading that says "Frequently Called" and you can follow the instructions above. Best of luck!
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back.
Thanks mymomcallsme
SOURCE: ihave a kyocera phantom cell phone i cant remember unlock code
go to nearest kyocera service center and unlock
SOURCE: How do you block calls
they have more than one slider. which model number? the most recent is this one. http://kyocerawireless.com/x-tc-phone/pdf/X-tc_user_guide_EN.pdf
SOURCE: kyocera hydro c5170 wont power on
Dear Brohter:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
