Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Aug 08, 2014
We have a Samsung French Door Refrigerator that maks a loud humming Sound. This is the second brand new one and both within hours make the loud humming noise.
Marc Taylor
Level 2:
  • Expert 150 Answers
  • Posted on Aug 08, 2014
Marc Taylor
Expert
Level 2:
Answers
150
Questions
Helped
47295
Points
453
Unless it is abnormally loud, it is the compressor.
5 Related Answers
Anonymous
  • Posted on Oct 19, 2006
SOURCE: Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Anonymous
  • 22 Answers
  • Posted on Nov 13, 2008
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Anonymous
  • 22 Answers
SOURCE: Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Anonymous
  • 1891 Answers
  • Posted on Dec 24, 2009
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Anonymous
  • 4323 Answers
  • Posted on Jul 01, 2011
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
My Samsung refrigerator occasionally makes a buzzing sound.
Buzzing and humming
This is the sound of water filling the ice maker, which will be louder if water pressure is too high. ... If the buzzing or humming is very loud, visit our Support Center to request service. https://www.samsung.com/us/support/troubleshooting/TSG01001032/
https://www.youtube.com/watch?v=OTFUHxHa01I
The fan is making a humming sound
when door open Temp inside goes up, when close door it tries ti bring temp inside back to where it needs it also it will generally only try to work when in closed environment don't sound like any "Fault" tho
1helpful
Loud buzzing from samsung french door fridge
Hi Debbie , sound like the evaporater fan blade is hitting the ake the back panel of the inside of the freezer and with the refrigerator off take off the blade and put back on . If that doesn't help replace the fan motor and blade . GOOD LUCK APPLIANCES R EN
1helpful
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Brand new won't get cold
Ours did the same thing and we returned it for an exact same model. Happy to report that the second one works just fine. Don't waste any more time on this defective one!
3helpful
2answers
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
