Ipad works and runs well but over the past week charging has been slow and is not charging fully I am using all original cables.
Sounds like battery is faulty. Replace it and check.
Gopakumar Gopalan Google
SOURCE: i got a ipad for
Most chances are the problem is the cable. You can try connecting the ipad to the pc, if you can connect then the problem is not the cable, but the charger.
You could try to use another cable from a friend with an ipad/ipod/iphone, just to be 100% sure.
Also try moving the cable around, the cable may be interrupted, it happened the same for me with my iphone.
Regards,
katharsys_i
SOURCE: i think my ipad got damp & now wont switch on
Your iPad is not a glass product, who tell you that it could be cleaned by using glass cleaner? You'd better to contact Apple for help, Good luck.
Android 4.0 Tablet PC
SOURCE: How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
SOURCE: I had bought an ipad
I was very happy when I got my hands on the new iPad. I didn't notice this at first, but when I took the tablet into my backyard, and my iPhone was able to pick up my router signal without a hassle; the iPad didn't pick up the network at all. This became a nightmare for me. A friend suggested trying the "Forget This Network" reset method, which used to work on the older models, but this didn't improve the wifi range at all. Right when I lost all hope, I came across WIRED magazine and found a review of Pong Research cases, After seeing the great feedback on their products, I bought one and it finally solve the <a href="http://www.pongresearch.com/new-ipad.html">new iPad 3 wifi issues</a> . The back cover has a built-in antenna in between its layers, which redirects and boosts the signals and range, allowing me to getting connected from much further away.
SOURCE: Transfer video from ipad to pc?
you neen't waste your money, try this app, it's free: Leawo iTransfer
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
