If it doesn't continue to show the license and owner screen, it means that the TomTom (navigation) software is not running properly. Often it means that the software is corrupt, and it has to be repaired or replaced.
If you are able to connect the TomTom device to a computer (using the USB port), select the TomTom disk, right click and select Properties, and run the TOOLs to check and repair the (TomTom) disk. After completing the repair, disconnect it (from the computer), restart the TomTom - turn it off and turn it back on, and see if you get it going normally. If not, you'll need to restore your navigation software from your backup and see if it works. Or you can download the navigation software from the TomTom website and copy it onto your GPS device.
