How do I check and replace the "water level sensor" on my Kenmore 80 Series Hvy Dty Washer? Water will not shut off on while filling the drum on any water level selection. Also washer will not operate on any wash cycle chosen as the water continues to fill. I can manually put washer on end of rinse cycle to drain washer and/or the spin cycles to drain washer. The drain from washer seems to be working. I need more help troubleshooting why washer will not stop filling to capacity and overflowing and continue filling. Any details you can help me with will be greatly appreciated.
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Testimonial: "Thanks for the link. Unfortunately, I was not able to locate anything regarding my problem because I could not figure out the search feature. Thank you for your help."
