2009 Hyundai i30 1.6 Logo
A
Anonymous Posted on Aug 08, 2014
Pin bluetooth code
I need the pin code to pair my i phone 4 to the BT v01. Thank You
Bill Lundberg
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Aug 08, 2014
Bill Lundberg
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
10039
Points
76
You can find many codes on yahoo. just enter the search information with the model number of your devise .although it has also been my experience that the default code is 0000 "4" zero's
3answers
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
3answers
Please someone help me. I've tried to connect to Bluetooth. I get so far along and then phone Bluetooth doesn't find the cars. Is there a fuse that might if gone? I did not get a manual with my car.
About 4,890,000 results (0.54 seconds) Search Results
    How to Fix Bluetooth Pairing Problems - Techlicious
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
    Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing...-/CP2/
    Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
    Bluetooth FAQ for Windows Phone ' Windows Phone How ...
    www.windowsphone.com/en-us/how-to/.../bluetooth-faq
    Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
    iPhone 6 not connecting to car Bluetooth ' Apple Support Commu
2answers
Bluetooth connection
You may try deleting your phone off of your car and re-pair
1helpful
2answers
How to hookup bluetooth in pioneer car stereo
you can try disconnection the power to the radio for 5 minutes (all the power not just the main power) then reconnect it and see it it reset.
How doI find my bluetooth pin
Bluetooth pairing with a vehicle and a cell phone will depend upon the phone type. Either the phone of the vehicle will tell you the code needed when pairing is in process. Many times, pairing doesn't require a code, especially if the phone is a "feature" phone and not a "smart" phone.
1helpful
I can't pair my iPhone Bluetooth to my Peugeot 207 , they find each other and then it asks for a code how do l get the code
Usually the pin is either four didgets ex> 0000 or the last four numbers of your cell phone number I suggest you try both of those
I dont have an owners manual and need to know how to sync my cell phone to the blue tooth
Friend,
First put the Bluetooth on and make it visible if there is a provision. Second, put the bluetooth on in the mobile. Third, on the cell phone search for BT devices. The other Bt should be visible. Select the BT device and from options, pair with it. Fourth, once paired, you are on.
I nned to know how to set up bluetooth in my car. it has all the functions on the steering wheel but I dont know how to set it all up . I also cannot find my manual !
You need to have the Bluetooth code (a four digit number that should be with your vehicle documents)
- Turn Bluetooth at your phone.
- With the car ignition key at Position 0 (Off), pressand hold the phone key on your steering wheel.
- Whilst still holding the phone key down, turn the ignition key to position 1.
- release the phone key after about 3 seconds.
- The car display should then show "BLUETOOTH PAIRING" or similar.
- Search for new bluetooth devices with your phone.
- When the BMW unit is detected, select and enter the 4 digit PIN.
- Your phone should now work via the cars Bluetooth interface
Hand book for bluetooth
According to the manual, do this:
  1. Park the car
  2. Press the Speech button
  3. Say "Setup"
  4. Say "Pairing Options"
  5. Say "Pair a phone" when prompted
  6. It will ask for a 4 digit pin -- tell it one (this is the pin you will use on the phone as well)
  7. Confirm the pin number if it asks
  8. start doing your pairing process on the phone, using the number you said in the step above
  9. Once it's paired from the phone, the car will ask to name the phone.
  10. Then the car will ask for connection priority, from 1 to 7, in case there is more than one paired phone in range -- it will connect to phone with the lowest number
  11. It may confirm your phone's name and priority, then it should tell you the pairing is complete.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
