Canon Powershot A2200 Black Digital Camera 2gb Kit Logo
A
Anonymous Posted on Aug 07, 2014
Why wont my canon powershot a2200 turn on after i dropped it
Jim Jordan
Level 3:
Master:
  • Canon Master 442 Answers
  • Posted on Aug 14, 2014
Jim Jordan
Canon Master
Level 3:
Master:
Answers
442
Questions
0
Helped
114763
Points
1360
I think you answered your own question there. There is a chance that the battery or memory card is not seated properly after the fall so you might try removing both, let the camera sit for 15-30 seconds and reinstall the battery/card and give it a go. Otherwise, there's most likely internal damage and the camera will need to be repaired or replaced.
5 Related Answers
Anonymous
  • 1382 Answers
  • Posted on Jun 01, 2010
SOURCE: my canon powershot sd 1200 wont turn on.
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Anonymous
  • 906 Answers
  • Posted on Jul 27, 2010
SOURCE: I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Anonymous
  • 50 Answers
  • Posted on Apr 05, 2011
SOURCE: i have the canon powershot
okay 1 of 2 things is wrong i think A) the lens or that area is broken some where B) the screen is broken what you need to do is send it to canon so they can tell you what the problem is
if the screens broken buy one off the internet open the camera using a eyeglass screw driver or you will strip the screws look how the screen is connector flip the switch and take out and replace you screen the video that i have linked isn't your camera but the assembly and disassembly should be the same and so the screen changing i cant help you if its problem A) my only advice buy a new camera if cost effective or get it repaired
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Apr 24, 2011
SOURCE: Unit Model: Canon Powershot A2200 Problem:
I suggest check in this link, some tips about fixing-lens-error-on-digital-camera.
Hope helps.
  • 102366 Answers
  • Posted on Aug 01, 2011
Press cursor-down (marked with a one-handed clock). Use cursor-up/down to select the desired delay. You'll find full details in the "Using the Self-Timer" section of the manual (page 60 in my copy). If you need a manual, you can download one at
http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_a2200#BrochuresAndManuals
My Canon Powershot A2200 giving white screen and closing automatically?
Question edited for clarity.
It sounds like the battery is flat or not holding a charge. Remove it and test the voltage with a multimeter. It should be 3.6 volts.
https://www.google.com/search?q=canon+powershot+a2200+battery
Canon a2200 it won't turn on
remove the battery, clean the contacts, then charge it and try putting it on again. thanks
May 27, 2014 • Cameras
I have A2200 cannon powershot camera but the flash is not working
You can Google your camera make/model and open the link to download your user manual in a PDF. I did this and picked the one below. Under the Table of Contents, pick Turning off the flash. The instructions to turn it on are there as well.
Hope this helps. Mike
CANON POWERSHOT A2200 USER MANUAL Pdf Download. www.manualslib.com > ... > Digital Camera > PowerShot A2200
View and Download Canon PowerShot A2200 user manual online. PowerShot A2200 Digital Camera. PowerShot A2200 Digital Camera pdf manual download.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
