Champion 3500/4000 Watt Portable Generator Logo
A
Anonymous Posted on Aug 07, 2014
050643359 where can I find a spark plug & ignition module on oahu.
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Repair stihl 45c
Check spark plug is functioning. (replace if unsure)
Check on off switch and wiring from switch to ignition module.
Check ignition module is functioning. (remove earth wire from ignition module, this should make sure the ignition module sends current to the spark plug and not to ground)
Check spacing between flywheel and ignition module. 0.25 filer guage.
3helpful
Hey there,i have a 1991 msuatng LX with the 2.3L ho engine running an 8 plug head. it sounds like i may have a misfire of some sort or my timing may be out but im not sure how to tell, could someone give...
Insert each wire on the proper terminal of the ignition coil. Ensure that the coil boots are fully seated and both locking tabs are engaged. The terminals are identified on the ignition coils. Install wires as shown in the illustration. The 2.3L firing order is 1-3-4-2 for both ignition coil assemblies.
Distributorless Ignition System In the distributorless ignition system (DIS), all engine timing and spark distribution is handled electronically with no moving parts. This system has fewer parts that require replacement and provides a more accurately timed spark. During basic operation, the EEC-IV determines the ignition timing required by the engine and a DIS module determines which ignition coil to fire.
Components
The distributorless ignition system (DIS) for the 2.3L twin spark plug engine consists of the following components:
  • Crankshaft timing sensor
  • DIS module
  • Two ignition coil packs
  • Spark angle portion of EEC-IV
Crankshaft Timing Sensor
The crankshaft timing sensor is a dual hall effect magnetic switch, which is actuated by the dual vane cup on the crankshaft pulley hub assembly. This sensor generates two separate signals, PIP (profile ignition pick-up) and CID (cylinder identification). The PIP signal provides base timing and RPM information, while the CID signal is used to synchronize the ignition coils. Initial timing (base timing) is set at 10 degrees BTDC and is not adjustable. Ignition Coil Packs
Two ignition coil packs are used for the 2.3L dual plug engine. The two ignition coil packs are triggered by the DIS module and are timed by the EEC-IV. Each coil pack contains two separate ignition coils for a total of four ignition coils. Each ignition coil fires two spark plugs simultaneously, one spark plug on the compression stroke and one on the exhaust stroke. The spark plug fired on the exhaust stroke uses very little of the ignition coils, stored energy, and the majority of the ignition coils, energy is used by the spark plug on the compression stroke. Since these two spark plugs are connected in series, the firing voltage of one spark plug will be negative with respect to ground, while the other will be positive with respect to ground. Refer to thePowertrain Control/Emissions Diagnosis Manual for additional information on spark plug polarity. DIS Module
The main function of the DIS module is to switch between ignition coils and trigger the coils to spark. The DIS ignition module receives the PIP and CID signals from the crankshaft timing sensor, and the SPOUT (spark out) signal from the EEC-IV module. During normal operation, PIP is passed on to the EEC-IV module and provides base timing and RPM information. The CID signal provides the DIS ignition module with the information required to switch between the coils for cylinders 1 and 4 and the coils for cylinders 2 and 3. The SPOUT signal (from the EEC-IV) contains the optimum spark timing and dwell time information. The dwell time is controlled or varied by varying the duty cycle (duration) of the SPOUT signal. This feature is called CCD (computer controlled dwell). Therefore, with the proper inputs of PIP, CID and SPOUT the DIS ignition module turns the ignition coils on and off in the proper sequence for spark control. CID is also sent to the EEC-IV micro-processor to allow for Bank to Bank fuel control. Failure Mode Effects Management
During some DIS system faults, the Failure Mode Effects Management (FMEM) portion of the DIS ignition module will maintain vehicle operation. If the DIS ignition module does not receive the SPOUT input, it will automatically turn the ignition coils on and off using the PIP signal. However, this will result in fixed spark timing (ten degrees BTDC) and a fixed dwell time (no CCD). If the DIS ignition module does not receive the CID input during engine cranking, random coil synchronization will be attempted by the module. Therefore, several start attempts (cycling the ignition from OFF to START) may be required to start the engine. If the DIS module loses CID input while engine is running, the module will remember the proper firing sequence and continue to fire to maintain engine operation. Dual Plug Inhibit
Dual Plug Inhibit (DPI) is a function of the EEC-IV that is only used when the vehicle is being started at temperatures -7° C (20° F) and below. During engine cranking, the EEC-IV will only fire the spark plugs on the right hand side of the engine. When the engine has started, the EEC-IV will send a signal to the DIS module to start normal dual plug operation. Ignition Diagnostic Monitor
The Ignition Diagnostic Monitor (IDM) is a function of the DIS module. The DIS module sends information on system failures to the EEC-IV which stores the information for diagnostic self test. The IDM signal also is used to drive the vehicle instrument tachometer, and test tachometer for system
I am looking for a spark plug wiring diagram for 1997 buick park ave 3.8 to see if the wires may be crossed.
Sometimes the coil packs are numbered from the factory --- Firing Order 1-6-5-4-3-2
Ignition Coil Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the service precautions in the beginning of this section
  2. Disconnect the spark plug wires from the coils
  3. Remove the fasteners securing the coil(s)
  4. Remove the coil(s) from the ignition control module
To Install:
  1. Install the coil(s) to the ignition module
  2. Install the coil fasteners
    • Torque to 40 in-lbs (4.5 Nm)
  3. Connect the spark plug wires to coil assemblies
Ignition Module Removal & Installation To Remove:
  2. Turn the ignition OFF
  3. Disconnect the 14-way connector from the ignition module
  4. Note the position of the spark plug wires and disconnect from the coils
  5. Remove the fasteners securing the coil(s)
  6. Remove the coils and the Ignition module from the bracket
To Install:
  1. Install the coils and the ignition module to the bracket
  2. Install the fasteners that retain the ignition coils to the ignition module
    • Torque the fasteners to 40 in-lbs (4.5 Nm)
  3. Install the nuts and washers that retain the ignition module to the bracket
    • Torque the screws to 70 in-lbs (8 Nm)
  4. Connect the spark plug wires to the coils assemblies
  5. Connect the 14-way connector to the ignition module
    • Torque the screw to 19 in-lbs (2.1 Nm)
How do I change an ignition coil on a V6 1997 Grand Am?
Removal Procedure
  1. Remove all the electrical connectors at the ignition control module.
  2. Note position of spark plug wires for installation
  3. Remove the spark plug wires from ignition coils.
  4. Remove the screws securing coil assemblies to ignition control module.
  5. Disconnect coils from ignition control module. Installation Procedure
    1. Install the coils to ignition control module.
    2. Install the screws and tighten to 4-5 Nm (36-44 lb. in.) .
    3. Install the fasteners securing assembly to engine and tighten to 8 Nm (70 lb. in.) .
    4. Install the spark plug wires as noted during removal.
    5. Install the electrical connectors to the ignition control module
  6. Hope this Helps !
Top Champion Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
