SOURCE: nvram mismatch
You have to install a brand new front display, the display board has a backup of the nvram, on boot the system board check the nvram and if it don't match it will return an NVram mismatch error
SOURCE: Error 950.10 NVRAM mismatch. how do I fix or
The way that I have found to fix this problem is to replace the logic board but when you do that, this is where the NVRAM mismatch comes in. Once you change the logic you also have to change the display op panel. That is what is giving you this error. You must change logic and op panel at same time and it will not give that error.
Testimonial: "Thank you very much for all your help"
SOURCE: Error 950.10 NVRAM Mismatch. Replaced the LCD
If the lcd that you put in came from another printer instead of Lexmark, it will say that because the lcd, riser card on rip board and rip board all contain nvram that has to be matched. an lcd from Lexmark will no have any nvram data and the nvram will be copied from the other two sources upon install. The only way to get the lcd out of another machine is to get all of the above parts from the same printer at the same time.
SOURCE: changed the motherboard on lexmark
Please click on the link below to see instructions on how to go about the procedure. http://bit.ly/j3es6B
