Hi there! If the spray trigger is stuck try removing and replacing the handle. Remove the two screws that attach the handle. Slide the handle off. Inspect the two rods inside of the handle for damages. Make sure both rods are pulled down. Replace handle and two screws. If the spray trigger is still stuck or if the rods were damaged in any way a replacement handle may be needed. If so I have included a link where you may purchase a replacement handle. Search Results Good luck!
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
