HP Deskjet 5440 InkJet Photo Printer Logo
Posted on Nov 08, 2007
Cleaning the print head on my HP5440 printer?
My printer has not been used for several weeks and the print is very faint. I have refilled the cartridge with black ink, but this maks no change. will I have to buy a new cartridge?
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Nov 08, 2007
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
18664
Points
82
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
After refiling ink, print is not getting corectly
Question is, was it printing correct before you refilled?
If not, the refill perhaps was not needed. Perhaps only cleaning the print head coulld have been enough. Print a head alignement page (just a little ink is used and only a few lines are printed) to check all the nozzles. When you see missing parts, you know you have to run one or a few cleaning cycles. When you don't use the printer often, please at least once a week switch it on and after a few minutes switch it of again. It will perform a cleaning cycle then, making the chanche of cloging minimal.
2answers
The black ink keeps drying up and will not print out black print
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
1helpful
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
2answers
Faint print out despite ink level not finish
is it a refilled one or not? try changing the catridge
Epson R340 ink issue
Purchase some inkjet head cleaner, remove all the carts and using a refilling syringe, gently inject the cleaning solution into the bay where the spikes are for the cartridges. Let it sit with that in to soak over night, and then run several cleaning cycles on it to pull the ink through. The CISS (continuous ink) shouldn't have damaged the heads in anyway. We sell them at work, and have never had one damage the heads, although they can be tempramental sometimes!
1helpful
Printer only printing bottom half of words
this usually happens when an air pass trough the valve of the ink upon refilling it.the effect would be an unequal distribution of the ink content. try first cleaning the head to disperse off the air inside the ink. if it doesnt solve the problem, i suggest try refilling it again and do the cleaning process a couple of times to clear out the air inside the cartridge.
No shadow density in photograph printing
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
k24674
Grand Canyon Tech
Grand Canyon Tech
