Once engine is running it will run out of gas. pull line at filter,gas. pull carb bowl gas. like an air lock. have taken off gas cap. filter is right dir. is there a vent on the carb to let gas flow? new filter. when tank is full (15 gl) seems to run for longer time. when half full and all is running will run out of gas and die. filter will be out at that time and after it dies will slowly see gas trickle in. pull line lots of gas. pull sed bowl on carb with line hooked up lots gas flows. the line is not plugged something is causing an air lock while it is running
if it has a fuel filter. check that. change the spark plugs.
SOURCE: It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
SOURCE: I had gas problems cleaned the carb,brass
Try to start it and then start spraying with it to make sure that your pressure relief valve is working. My son-in-law had this problem and it was because the pump built up so much pressure that the engine couldn't overcome it and it would stall out
SOURCE: Honda GX 240 on woodsplitter
Install a new plug, and make sure your gas mixture is not to rich, And you air cleaner is clean
SOURCE: motor will start on choke
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
